IF you don't remove drain plug(17mm allen) you can't drain oil. Then you dilute 2.5-3 litres more in AT with fresh oil. 7L total.
If you drain it, then its only 4 litres left in AT.
I didn't find any problems with shallow hole for 17mm. It has oring and doesn't need much force (like AF40 with metal washer)...
